first image
Add Note Step 16
  • Disconnect the newly-revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
first image
Add Note Step 17
  • Disconnect the (once again) newly-revealed hard drive cable.
first image
Add Note Step 18
  • Peel up the foil tape between the fan and the optical drive.
  • Remove the Phillips screw securing the display data cable to the metal framework.
Notes
There are no notes
