View profile
Logout
« Previous
Next »
Page 3 of 12
Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
Remove the following 4 screws from the back of the computer:
Two 7 mm Philips on the far sides.
Two 10.5 mm Phillips toward the center.
Do not over-tighten these; you can cause the case to distort.
Next » « Previous
$2.95 · 50+ in stock
$4.95 · 50+ in stock
$2.95 · 16 in stock
$299.95 · 2 in stock
$24.95 · 50+ in stock
$7.95 · 50+ in stock
$7.95 · 13 in stock
$59.95 · 50+ in stock
$6.95 · 50+ in stock
1024
