Page 1 of 1
Installing MacBook Core Duo Display
- Author: iRobot
- Difficulty: Difficult
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
Sections
- Battery 2 steps
- Memory Cover 2 steps
- Upper Case 8 steps
- Optical Drive 11 steps
- C-Channel 3 steps
- Display 8 steps
- View:
- Paginated
- Full width
Edit
Step 11
Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
Edit
Step 20
Remove the Phillips screw securing the optical drive.
The Bluetooth cable may be covering the screw; carefully push it aside before removing the screw.
Do not over-tighten this screw when re-mounting. You could break the plastic enclosure.
After removing the screw, push the metal tab backwards, towards the fan, to release the front of the optical drive.
Edit
Step 27
Display
Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
Pulling on this connector vertically will break the socket off the logic board. This connector should be removed horizontally by gently pulling the microphone cable toward the screen while working a spudger between the connector and the socket.
Edit
Step 33
Hold the display with one hand while removing the screws from the left hinge mount.
Remove the following 3 screws from the left hinge mount:
One 6 mm smaller diameter Phillips from the right side.
One 6 mm larger diameter Phillips from the middle.
One 10 mm Phillips from the left side.
Lift the left hinge mount out of the computer.
Page 1 of 1
