first image
Add Note Edit Step 10  ¶
  • Remove the two Phillips screws from the optical drive side of the computer.
    • Two 5.2 mm Phillips #00, with Shank (2.3mm dia. x 3.5 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
  • It is not necessary to remove the similar screws on the other side of the computer.
first image
Add Note Edit Step 11  ¶
  • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
  • Starting near the display and working around to the front of the computer, pry up on the upper case. A plastic opening tool or a medium hard guitar pick may help you to do this.
  • The upper case is likely to stick at the connection above the optical drive. If this is the case, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening.
first image
Add Note Edit Step 12  ¶
  • While holding up the upper case, pull up the black tab of the silver cable away from its connector.
  • If there is no black tab, you can also use a spudger to gently pry the connector from its housing. This connector is tall, so be sure to pry straight up.
  • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Coin
$2.95 · 16 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Device Products
Arctic Silver Thermal Paste
$8.95 · 50+ in stock
MacBook MagSafe DC-In Board
$29.95 · 29 in stock
MacBook Display Inverter
$49.95 · 23 in stock
MacBook 13.3" LCD Panel
$149.95 · 50+ in stock
Notes Add Note Notes are offturn on
