first image
Add Note Step 19
  • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
first image
Add Note Step 20
  • Remove the Phillips screw securing the optical drive.
  • The Bluetooth cable may be covering the screw; carefully push it aside before removing the screw.
first image
Add Note Step 21
  • Lift the Bluetooth antenna board from the right side of the optical drive.
Add NoteNotes: Step 19
Flag Reply by t0m Jul 12 @ 2:54 PM
I had to unscrew a screw securing flat ribbons keeping cables in position between beeper and fan to reach for the dvd screw
Add NoteNotes: Step 20
Flag Reply by xtian Jun 24 @ 9:23 PM
STEP 20 - IMPORTANT= This screw secures a mounting bracket on the optical drive. This bracket's eyelets are slotted. The right side of the bracket has a tab inserted in the bottom case. After removing the screw, use the spudger to slide the bracket to the left. This disengages the tab from the right side of the case, thus allowing the optical drive to be lifted out in step 23.
