first image
Add Note Step 28
  • Peel up the silver foil tape from the optical drive.
  • You'll want to reapply this tape in the same position on your replacement drive.
first image
Add Note Step 29
  • Remove the two Phillips screws securing the mounting bracket to the right side of the optical drive.
  • This bracket is designed to slide back and forth slightly, so don't tighten the screws so much that the bracket is unable to slide.
first image
Add Note Step 30
  • Use a spudger to pry the gray Bluetooth antenna holder off the top of the optical drive.
  • You'll want to reapply this piece in the same position on your replacement drive.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Congratulations!
Share your repair story!
To reassemble your device, follow these instructions in reverse order. For more information, check out the MacBook Core 2 Duo device page.
Did you successfully follow this guide?
Notes
There are no notes
