Installing MacBook Air Models A1237 and A1304 AirPort/Bluetooth Board
  • Add Note x
  • x 4
Reclaim your singular source of internet connectivity by replacing your broken AirPort/Bluetooth board.
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following 10 screws securing the lower case to the Air:
    • Six 2.8 mm Phillips screws.
    • Two 3.8 mm Phillips screws.
    • Two 5.4 mm Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
first image
Add Note Edit Step 3 — Battery  ¶
  • Disconnect the battery connector by pulling it straight out of its socket.
first image
Add Note Edit Step 4  ¶
  • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
first image
Add Note Edit Step 5  ¶
  • Lift the battery out of the Air.
first image
thumb image 1
thumb image 2
Add Note Edit Step 6 — AirPort/Bluetooth Board  ¶
  • Remove the two following screws securing the AirPort/Bluetooth board bracket to the upper case:
    • One 4.7 mm Phillips.
    • One 3.9 mm Phillips.
  • Lift the AirPort/Bluetooth bracket out of the upper case.
first image
Add Note Edit Step 7  ¶
  • Using a spudger, pry the AirPort/Bluetooth ribbon cable connector straight up off the AirPort/Bluetooth board.
first image
Add Note Edit Step 8  ¶
  • Use a spudger to pry the three antenna cables up off the AirPort/Bluetooth board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 9  ¶
  • Remove the single 3.2 mm Phillips screw from the upper right corner of the AirPort/Bluetooth board.
  • Lift the AirPort/Bluetooth board out of the upper case.
For more information, check out the MacBook Air Models A1237 and A1304 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
