first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • All three antennas need to be removed before accessing the hardware underneath.
  • Two black posts secure the large Airport antenna board to the internal frame. The other two antennas (on the right) can be removed by pulling them directly upward.
  • Remove the large antenna by squeezing both black posts together and gently lifting the antenna board from the posts.
  • Remove the other two antennas by pulling them directly upward.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • Rotate the mini 180 degrees.
  • Use a spudger to peel back the black tape and release the antenna cable.
  • Carefully lift the remaining two antennas from the right side of the mini.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • Remove the four black Phillips screws holding the internal frame to the bottom housing.
  • Remove the black Phillips screw from the bottom left corner.
  • Remove the black Phillips screw from the top left corner. This particular screw is hidden from view.
Next » « Previous
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
Spudger
$2.95 · 50+ in stock
1.5" Thin Putty Knife
Soldering Station
$24.95 · 35 in stock
Solder
$4.95
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
