Installing Mac mini Model A1283 Terabyte Drive
Add Note Introduction
Difficulty: Very difficult
We tried to put a whopping terabyte worth of storage in a Mac mini -- and succeeded!
This guide walks you through the process of replacing the stock hard drive and optical drive with TWO 500 GB hard drives.
Warning: Although you're welcome to do this at home, this surgery is at your own risk. Make sure to back up any important data prior to working on your mini's hard drive. We'll post more information regarding heat and performance as soon as we have it available.
Paginated Single Page Steps
first image
Add Note Step 1 — Terabyte Drive
  • We decided to see if we could stuff a full terabyte worth of storage into our new Mac mini. Why would anyone possibly want this much storage?
    • Bragging rights. Mac minis come with either 120, 250, or 320 GB standard. Yours has 1 TERABYTE.
    • Built-in Time Machine. Sure, you can hook up an external drive, but it's sure nice not to have cables everywhere.
    • RAID -- mirroring, striping, concatenating -- take your pick.
  • And seriously, with that much space, who needs an optical drive?
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 2
  • We're going to:
    • Swap out a the existing hard drive for a 500 GB drive.
    • Then remove the optical drive and install another new 500 GB drive in its place.
  • Carefully insert a putty knife into the crevice between the top cover and bottom housing. Start on the left side first.
  • Gently enlarge the existing crevice by twisting the putty knife downward and away from the mini.
  • Repeat the prying motion until a portion of the bottom housing has been nudged upward.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 3
  • Repeat the same prying procedure on the right side.
  • The top cover should now be marginally separated from the bottom housing. Use your fingers to completely separate the two, starting with the I/O side of the mini.
  • The top cover does not have any cables attaching it to the bottom housing; it should now be completely detached from the bottom.
Add NoteNotes: Step 1
Flag Reply by asjogren Mar 10 @ 1:32 AM
Does anyone know if the SATA controller supports port multiplication?
Flag Reply by andresskl Mar 13 @ 5:17 PM
Isn't this hack available for previous minis? I've got the mini mid-2007, 2.0GHz. Thanks!
Flag Reply by andreas7 Mar 16 @ 6:29 PM
Quote from andresskl:
I don't think so because the previous minis the optical drive and the hard drive did differ in the interface. One had Parallel ATA and one had SATA. But if you find a matching harddrive with the right conection type you might still succeed.
Flag Reply by plugwash Mar 31 @ 1:21 PM
Earlier minis use an IDE cd drive. This raises 2 issues.
Firstly i'm not aware of anyone who makes an adaptor/cable from the slimline IDE CD connector in the mini to a hard drive (there are plenty of adaptors for connecting a slimine IDE CD drive to a normal IDE cable but i've never seen one going the other way). Making a custom adaptor would be a major PITA (you would probablly have to get a custom pcb made).
Secondly 2.5 inch IDE hard drives seem to top out at 250G so the maximum you could get in such a mini would be 750G (500GB sata in place of the original hard drive and 250GB IDE in place of the CD drive).
Flag Reply by waypts Apr 14 @ 4:05 PM
Help! Is it possible to put in a 1 TB Sata Drive instead of two 500GB drives?
iFixit Staff
Flag Reply by Kyle Wiens Apr 15 @ 4:29 PM
Quote from waypts:
It's a notebook hard drive, and the largest drives currently available are 500 GB. Eventually they'll make notebook drives with that much capacity.
Flag Reply by macthemike Jul 23 @ 7:09 PM
Quote from kyle:
Would it be possible to connect a 3.5" internal 1TB SATA drive and just leave the case open (since it won't fit inside like a notebook drive would)?
Flag Reply by cjc1959au Sep 18 @ 4:56 PM
Quote from kyle:
Sorry, but WD is shipping 750GB and 1TB 2.5" drives now. And I think Toshiba has a 640GB 2.5" drive as well (19SEP09)
Flag Reply by JerryTsai 4 days ago
The largest storage of 2.5" IDE HDD is 320G.
