first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 25  ¶
  • The one drawback to this hack is that we removed the optical drive. Fortunately, Apple's provided an easy solution, thanks to the MacBook Air.
  • You can use Remote Disc to share the optical drive of a nearby Mac or PC.
  • Remote Disc is not activated on the Mini, but fortunately turning it on is simple. Just type the following two commands in Terminal:
    • defaults write com.apple.NetworkBrowser EnableODiskBrowsing -bool true
    • defaults write com.apple.NetworkBrowser ODSSupported -bool true
  • Restart, and you're all set.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 26  ¶
  • If you're like us and Time Machine just isn't enough, you can RAID the two drives together to make a single 1 TB drive.
  • Instructions are elsewhere online to do this, but the basic steps are:
    • Back any data up, then boot off a different startup disc.
    • Format both drives as Mac OS Extended.
    • Create a new 'RAID set', and add both drives to it. You can choose 'Concatenated Set', mirrored RAID 1, or striped RAID 0.
    • After you create the drive array, you can copy an OS onto it from a backup (as we did), or you can install OS X from scratch.
first image
Add Note Edit Step 27  ¶
  • There you have it: 930 GB of usable space!
  • Why are we 70 GB short? It depends on how you define a terabyte.
Next » « Previous
For more information, check out the Mac mini Model A1283 device page.
Did you successfully follow this guide?
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
Spudger
$2.95 · 50+ in stock
1.5" Thin Putty Knife
Soldering Station
$24.95 · 37 in stock
Solder
$4.95
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 17 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
