Page 1 of 1
Installing iPod Shuffle 1st Generation Memory Board
- Author: iRobot
- Difficulty: Difficult
The memory within the iPod.
Sections
- Hold Switch 2 steps
- Casing 7 steps
- USB Port 3 steps
- Battery & Logic Board 4 steps
- Memory Board 2 steps
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit Step 4 ¶
The following step can be challenging and time consuming. Be sure to go slowly and have patience to prevent damaging your iPod.
Use an Exacto knife to separate the glue holding the USB port on the iPod. Run the knife along the seam between the two sections of the iPod until the glue is separated. Expect to run the knife along this edge 20-30 times before the glue will be entirely freed.
Edit Step 6 ¶
Use a spudger to push on the headphone jack and slide the USB port out of its housing.
If the USB port doesn't come free, check to make sure all the glue holding the USB port in place has been released. Pulling on the USB port itself is not recommended as there is a fragile ribbon cable that can be ripped if the USB port suddenly comes free.
Edit Step 9 ¶
Turn the iPod so that the click wheel is facing up. This will prevent the battery indicator from falling out.
If the battery indicator does fall out, don't forget to replace it prior to reassembling the iPod. Getting the battery indicator back in place can be tricky. You'll have to slide it in from the end of the iPod's casing and get it to fall into its slot in the casing.
Slide the iPod out of its casing.
This guide has been completed 1 time.
Page 1 of 1
