Installing iPod Nano 4th Generation Logic Board Assembly
  • Add Note x
  • x 20
Replacing the logic board assembly gives you new flash memory as well as a new battery.
Sections
Tools
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Glass Panel  ¶
  • Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
  • Pry the top bezel off the adhesive securing it to the display retainer.
  • At this point the hold switch slider is free and may fall. Be careful not to lose it.
first image
Add Note Edit Step 2  ¶
  • Remove the hold switch slider from the top of the Nano.
first image
Add Note Edit Step 3  ¶
  • Remove the two angled Phillips screws from the two corners of the display retainer.
  • These screw heads are extremely small and easily stripped.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Plastic Opening Tools
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 47 in stock
Anti-Static Wrist Strap
$7.95 · 22 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Device Products
iPod Nano Gen 4 Replacement Battery
$14.95 · 45 in stock
iPad USB 10W AC Charger
$19.95 · 7 in stock
Notes Add Note Notes are offturn on
