Page 1 of 1
Installing iPod Nano 4th Generation Battery Replacement
Replace the battery in your iPod Nano 4th Generation.
- Author: Walter Galan
- Difficulty: Very difficult
Replacing the battery requires a fine tip soldering iron and is a difficult job that only experienced solderers should attempt.
Sections
- Glass Panel 7 steps
- Display 5 steps
- Logic Board Assembly 8 steps
- Battery Replacement 3 steps
Tools
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 4
Insert an iPod opening tool between the outer case and the display retainer.
Use the tool to slide the display assembly out of the case slightly.
Do not rotate the display retainer about the top edge of the display, as it is attached to a thin steel bracket that is easily broken.
Do not forcefully remove the display retainer, as the hold switch cable is liable to snap.
Edit
Step 16
Use the flat end of a spudger to separate the battery from the adhesive securing it to the outer case.
The lithium polymer battery used in the Nano is very flexible. Try not to deform it excessively while separating it from the outer case.
Use the flat end of a spudger to push the logic board assembly and battery slightly out of the bottom of the Nano. Stop once it pops out a little bit.
Edit
Step 21
Battery Replacement
Peel the hold switch cable from along the edge of the battery and lay it aside. The hold switch cable is not attached to the battery.
The battery is held on to the logic board by a strong adhesive. Force may be required to remove the battery from the logic board.
Pry the battery off the adhesive securing it to the metal tray on the logic board.
Edit
Step 22
The battery on the fourth generation nano is attached via solder pads with small holes that go through the battery ribbon cable and attach to flat pads on the face of the logic board. In this step, you will heat each solder pad individually while using a metal spudger to pry it up from the logic board.
DO NOT bridge the connection between the solder pads both on the board and on the ribbon cable with your spudger. Shorts have the potential to ruin the logic board.
Beware of overheating the board and the cable. Only hold the tip of the iron against the pad long enough to let the solder melt. Excess heat buildup has the potential to ruin the logic board or melt the ribbon cable. Consider letting the board cool off between melting each solder pad.
Start working from one side of the battery ribbon cable. In our case, we started on the left. Heat the leftmost solder pad while gently prying up from under the ribbon cable to free it from the board.
Page 1 of 1
