Installing iPod Nano 3rd Generation Logic Board
- Author: Walter Galan
- Difficulty: Difficult
The motherboard/bat
Relevant parts
- View:
- Paginated
- Full width
Edit Step 1
Rear Panel
Please be aware that removing the rear panel from the back of the iPod will cause considerable damage to the rear panel. We highly recommend purchasing an additional rear panel to properly reassemble the iPod.
Before opening your iPod, ensure that the hold switch is in the locked position.
Edit Step 2 ¶
The rear panel is secured to the front case by eight clips permanently attached to the rear panel. These clips lock onto small tabs machined into the front case.
To free the tabs, they must be pushed toward the center of the Nano. Note the location of all tabs on the rear panel. When using an iPod opening tool to free the rear panel, be sure to work the tool at the location of these clips.
To aid in visualization, the two clips boxed in red are located closest to the headphone jack.
Edit Step 3 ¶
Opening the iPod can be challenging. Don't get discouraged if it takes you a few tries before the iPod is opened.
Insert the large iPod opening tool into the seam between the front case and rear panel of the iPod, above the dock connector. The tool's edge should point toward the rear panel to prevent any accidental scratching of the aluminum front case.
Page 1 of 5
