Installing iPod Nano 2nd Generation Bottom Bezel
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
  • x 4
The plastic part on the bottom of the iPod.
first image
Add Note Edit Step 1 — Bottom Bezel  ¶
  • Before opening your iPod, ensure that the hold switch is in the locked position.
first image
Add Note Edit Step 2  ¶
  • When removing the the bottom bezel, be sure not to bend the plastic surrounding the dock connector.
  • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic bezel
  • Lift the bottom bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
For more information, check out the iPod Nano 2nd Generation device page.
Did you successfully follow this guide?
Required Tools
Plastic Opening Tools
$2.95 · 50+ in stock
Related Products
iPod Nano Gen 2 Bottom Bezel
$9.95 · 12 in stock
Notes Add Note Notes are offturn on
