Installing iPod Mini Battery
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
  • x 136
Battery not lasting long? Swap it out.
Sections
Tools
first image
Add Note Edit Step 1 — Top Bezel  ¶
  • Before opening your iPod, ensure that the hold switch is in the locked position.
first image
Add Note Edit Step 2  ¶
  • Carefully insert a small flathead screwdriver in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
  • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
  • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
first image
Add Note Edit Step 3  ¶
  • Lift the top bezel off of the iPod.
first image
Add Note Edit Step 4 — Bottom Bezel  ¶
  • Carefully insert a small flathead screwdriver in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
first image
Add Note Edit Step 5  ¶
  • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
  • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
first image
Add Note Edit Step 6  ¶
  • Lift the metal retaining bracket out of the iPod.
first image
Add Note Edit Step 7 — Battery  ¶
  • Use a spudger or the tip of your finger to carefully disconnect the orange click wheel ribbon from the logic board.
first image
Add Note Edit Step 8  ¶
  • Remove the two #00 Phillips screws securing the headphone jack to the casing.
first image
Add Note Edit Step 9  ¶
  • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
  • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
  • Be careful not to break the logic board connector off the iPod. The ribbon cable sits at the very top of the connector.
first image
Add Note Edit Step 10  ¶
  • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
first image
Add Note Edit Step 11  ¶
  • Lift the battery off of the logic board and lay it to the side of the iPod.
first image
Add Note Edit Step 12  ¶
  • Carefully disconnect the battery from the logic board. Make sure to pull only on the connector and not on the battery wires.
For more information, check out the iPod Mini device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
