Installing iPod Classic Rear Panel
  • Author: iRobot
  • Difficulty: Very difficult
  • Add Note x
  • x 12
The shiny rear half of your iPod case.
first image
  • Apple designed their new iPods to be very difficult to take apart without destroying major components. Because of the metal faceplate, the metal backing, and the 13 (yes, 13) metal clips holding the case together, this is one of the toughest iPods to disassemble. Proceed with caution and the warning that you may significantly damage your iPod beyond its present condition. Also, you may want a few extra pairs of iPod opening tools during installation, as they are easy to ruin when opening the iPod. Have fun!
  • Before opening your iPod, ensure that the hold switch is in the locked position.
first image
Add Note Edit Step 2  ¶
  • Opening this iPod is challenging. Don't get discouraged if it takes you a few tries before the iPod is opened. One thing to notice is the angle of the plastic iPod opening tool's tip while inserting it into the iPod. Ideally, the angle should be as vertical as possible while still clearing the edge of the rear panel.
  • Insert a plastic iPod opening tool into the seam between the front and back of the iPod.
first image
Add Note Edit Step 3  ¶
  • Insert another plastic iPod opening tool into the seam between the front and back of the iPod, leaving at least 1.5 inches of space between the two tools.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
1.5" Thin Putty Knife
Metal Spudger
Plastic Opening Tools
Related Products
iPod Classic Thin Rear Panel
$29.95 · 10 in stock
iPod Classic Thick Rear Panel
$29.95 · 5 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
