Installing iPod 5th Generation (Video) Click Wheel Button
Add Note Introduction
This guide shows how to remove the click wheel button from an iPod Video.
Tools used in this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Case
  • Before opening your iPod, ensure that the hold switch is in the locked position. The slider should be all the way to the right if your iPod is facing you.
first image
Add Note Step 2
  • Opening the iPod can be challenging. Do not get discouraged if it takes you a few tries before the iPod is opened.
  • Free the first retainer clip on the bottom of the iPod using the large iPod opening tool. The tool's edge should point towards the metal back case to prevent scratching the plastic front.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Step 3
  • There are five retaining clips on each side of the iPod. The large iPod opening tool will be used to separate the plastic front from the metal back of the iPod.
  • Insert the large iPod opening tool into the left side of the iPod, with the edge of the tool pointing towards the metal back.
  • Gently enlarge the existing crevice by wiggling the large iPod opening tool and moving it to the left.
  • Continue doing so until the entire side of the iPod is loose.
  • You can then insert the small iPod opening tool near the Hold button. Be very careful while inserting the tool, as the display is very fragile.
Add NoteNotes: Step 1
iFixit Staff
Flag Reply by Miroslav Djuric Mar 10 @ 1:24 PM
Nice guide!
Flag Reply by jimmora Jul 27 @ 7:22 PM
Quote from miro:
Nice guide!
Hi - no need to disconnect all those cables, take out the HD, etc. Skip all the way to unscrewing and save the effort of trying to sneak those cables back into place.
Flag Reply by Cyrus Jul 28 @ 9:42 AM
One word of advice: My cousin opened his vid from the top and accidentally cracked his screen in half. I would suggest to start opening it from the bottom, near the dock connector.
Flag Reply by wittweb Jul 28 @ 8:33 PM
I too just cracked the screen in half by starting at the top. The screen is completely shot now. Got a guide for replacing screens? These things are hard to open. Be careful! Have someone hold it while you slowly pry it open.
Flag Reply by kilbot Aug 7 @ 6:10 AM
Hey all
I followed the instructions and it seems to have worked perfectly except that now my ipod is not playing in proper stereo. Both earphones are working but when it comes to a part in a song where there is like a single instrument playing by itself it is totally silent. If you listen to thrash metal or hardcore punk as i do it's when there is like a guitar breakdown or something like that. Do you think my parts were faulty or have I done some damge when i did the repair? Discuss!!
Flag Reply by spdmonkey Aug 7 @ 7:56 PM
I just replaced a broken screen and battery tonight in my early ipod video 30g. I think you may have not got the audio cable back in correctly or you may need to replace the earphone connector. This site is great and just last week i used ifixit parts to fix my ibook dc in then tonight my ipod. Saved a ton of cash and the service is awesome.
Flag Reply by qwerty Aug 21 @ 1:07 PM
ive just replaced my screen and its working fine, apart from when i switch it on it says i need to connect to itunes, when i do that it says that it needs resetting to factory settings, and when i do that it gets to the end then just says i need to reset it again???? any help please?
Flag Reply by jimixiaozi Aug 26 @ 1:47 AM
very useful
Flag Reply by greg29 Sep 14 @ 8:09 PM
Replaced my screen that somehow cracked in my bag while it was under the seat in front of me on an airplane. 80GB 5.5g video.
The only thing I'll add is that when I first installed the new screen, I would get all kinds of weird artifacts after putting the case back together. It would be fine with the case open but as soon as pressure was applied it would turn white and go crazy. I looked at the old screen and saw a small white plastic sticker covering the electronics on the old screens ribbon cable, so I peeled it off and put it on the new screen's ribbon cable and everything went back together and worked perfectly. Placing pressure on these components must cause trouble and I guess the sticker disperses the pressure to prevent this. It's like new.
I was really bummed because I have Rockbox running on this thing and no ipods since the 5.5g will run it, and you can't buy those anymore without spending a fortune. Thank you ifixit.com.
Flag Reply by stumped Sep 18 @ 11:49 AM
I followed all the steps for taking apart my 5th gen Ipod video, replacing the factory battery with a new one. Now my click wheel does not work. I've tried resetting it without success. Any suggestions?
Flag Reply by swean Sep 20 @ 3:39 PM
i followed all the steps and fix it up by myself ~ haha THX~
Flag Reply by hidi00z Nov 5 @ 6:12 AM
Quote from greg29:
Replaced my screen that somehow cracked in my bag while it was under the seat in front of me on an airplane. 80GB 5.5g video. The only thing I'll add is that when I first installed the new screen, I would get all kinds of weird artifacts after putting the case back together. It would be fine with the case open but as soon as pressure was applied it would turn white and go crazy. I looked at the old screen and saw a small white plastic sticker covering the electronics on the old screens ribbon cable, so I peeled it off and put it on the new screen's ribbon cable and everything went back together and worked perfectly. Placing pressure on these components must cause trouble and I guess the sticker disperses the pressure to prevent this. It's like new. I was really bummed because I have Rockbox running on this thing and no ipods since the 5.5g will run it, and you can't buy those anymore without spending a fortune. Thank you ifixit.com.
Flag Reply by hidi00z Nov 5 @ 6:15 AM
Quote from hidi00z:
hey, greg29 i have the same situation with my 5th gene iPOD, right now the display it's white and i want to know if you show where i need to put the white sticker or another kind of sticker because the old dispelay i throw it away...thanks,
