Page 1 of 1
Installing iPod 4th Generation or Photo Front Panel
- Author: iRobot
- Difficulty: Moderate
The plastic front half of your iPod case.
Sections
- Rear Panel 8 steps
- Hard Drive 1 step
- Hard Drive Cable 3 steps
- Logic Board 5 steps
- Display 1 step
- Front Panel 2 steps
- View:
- Paginated
- Full width
Edit Step 2 ¶
Opening the iPod can be challenging. Don't get discouraged if it takes you a few tries before the iPod is opened.
Insert a large iPod opening tool into the seam between the plastic front and metal rear panel of the iPod, near the headphone jack. The tool's edge should point towards the metal rear panel to prevent any accidental scratching of the plastic front.
Run the tool along the top seam toward the upper left corner of the iPod. Press the tool into the corner, creating a small gap on the side of the case.
Edit Step 4 ¶
There are five retaining tabs on each side of the iPod.
With the large iPod opening tool still inserted in the top seam, press a small iPod opening tool into the gap you just created.
Run the iPod opening tool down the side seam, releasing all five tabs.
It may be necessary to wiggle the tool while working your way down the seam to free all the tabs.
Edit Step 16 ¶
Slide the orange click wheel ribbon cable out of its connector. You must unlock this connector before sliding the ribbon cable out. The locking mechanism is on the opposite side of where the cable is inserted - it swivels upwards 90 degrees. Use a plastic spudger to lift the locking mechanism.
This guide has been completed 12 times.
Page 1 of 1
