Installing iPod 2nd Generation Battery
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
  • x 3
Battery not lasting long? Swap it out.
Sections
Tools
Relevant parts
first image
Add Note Edit Step 1 — Rear Panel  ¶
  • Before opening your iPod, ensure that the hold switch is in the locked position.
first image
Add Note Edit Step 2  ¶
  • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
  • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
first image
Add Note Edit Step 3  ¶
  • Continue to run the opening tool along the side of the case until all five tabs have been released.
Next » « Previous
Required Tools
Plastic Opening Tools
$2.95 · 50+ in stock
Popular Products
T6 Torx Screwdriver
$4.95 · 50+ in stock
54 Bit Driver Kit
$24.95 · 50+ in stock
Tri-wing Y1 Screwdriver
$9.95 · 27 in stock
JIS Driver Set
$22.95 · 48 in stock
Notes Add Note Notes are offturn on
