first image
Add Note Edit Step 19  ¶
  • We recommend that you clean the exposed surface of the board with a soft cloth or sponge and a small amount of rubbing alcohol.
  • Melt a small solder bead directly onto the metal connector on the board by placing the soldering iron onto the metal connector and then pressing solder against the tip and the board.
  • Once a small amount of solder has melted onto the board, lift the solder away first and then the soldering iron.
first image
Add Note Edit Step 20  ¶
  • The solder bead should look like a small dome or hemisphere. If it is flat or jagged, simply place the soldering iron back on the solder to re-melt it and then pull the soldering iron away. It may require a little more solder if this does not work.
first image
Add Note Edit Step 21  ¶
  • Attach the red lead first, followed by the white lead, and finish with the black lead.
  • Place the wire from the new battery onto the new solder bead.
  • Press the tip of the soldering iron onto the solder bead until it melts.
  • Slide the wire lead into the liquid solder until it is in the center of the bead, then remove the soldering iron.
  • Continue with the other two connections the same way, taking special care not to solder two of the connectors together.
Next » « Previous
For more information, check out the iPhone 1st Generation device page.
Did you successfully follow this guide?
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Metal Spudger
Soldering Station
$24.95 · 36 in stock
Solder
$4.95
Related Products
iPhone Gen 1 Replacement Battery
$14.95 · 18 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 14 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
