Page 1 of 1
Installing iMac Intel 27" Power Supply
- Author: Andrew Bookholt
- Difficulty: Moderate
Use this guide to replace a faulty power supply.
- View:
- Paginated
- Full width
Edit Step 1
Glass Panel
Stick a suction cup near each of the two top corners of the glass panel.
To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Edit Step 2 ¶
Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
Edit Step 4 ¶
Carefully lay the iMac stand-side down on a flat surface.
Due to tight tolerances, you will have to use a thin hooked tool to lift the display out of the outer case. As seen in the third picture, we made one out of a bent paperclip.
Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
After lifting the top edge of the display on one side, hold it out of the outer case while you use a hooked tool to lift the other side.
Do not lift the top edge of the display out of the outer case too far, as several short ribbon cables still connect the two components.
Edit Step 10
Power Supply
The next few steps bring your hands close to the exposed face of the power supply. To avoid a high voltage shock from the many large capacitors attached to the board, do not touch the face of the power supply.
Disconnect the DC-In cable by using your index finger to depress the locking mechanism on the back of the connector while you pull the connector away from its socket on the power supply.
Once the locking mechanism has cleared the socket, pull the DC-In connector away from the power supply.
Page 1 of 1
