Page 1 of 1
Installing iMac Intel 20" EMC 2266 Ambient Temperature Sensor Cable
- Author: Walter Galan
- Difficulty: Moderate
Make sure to keep an accurate temperature reading by replacing the ambient temperature sensor cable.
Sections
- Access Door 1 step
- Glass Panel 2 steps
- Front Bezel 3 steps
- Display Panel 4 steps
- Left Speaker 4 steps
- CPU Fan 2 steps
- Ambient Temperature Sensor Cable 1 step
- View:
- Paginated
- Full width
Edit Step 2
Glass Panel
The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter.
Stick two suction cups to opposing corners of the glass panel.
To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Edit Step 3 ¶
Gently pull the glass panel straight up off the iMac.
The glass panel has several positioning pins around its perimeter. To avoid shearing these pins off the glass panel, be sure to only pull straight up during removal.
Be meticulous about cleaning the LCD and the inside face of the glass panel before reinstallation, as any fingerprints or dust trapped inside will be annoyingly visible when the display is on.
Edit Step 4
Front Bezel
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
On the 24" iMac Intel Model A1225, the bottom center two screws are long (26mm), four on sides (two left, two right) are medium (18mm), and the remaining 6 (four top, two bottom corners) are short (14mm).
Edit Step 5 ¶
The front bezel is still attached to the iMac by the microphone cable.
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
When reinstalling the front bezel, start at the lower edge and make sure it is flush with the rear case before lowering the top edge onto the iMac.
Edit Step 10 ¶
With the display panel still lifted, disconnect the four inverter cables.
During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush on the edges of the rear case.
(combined into one plug in on the 24")
Page 1 of 1
