Installing iMac Intel 20" EMC 2266 Access Door
  • Add Note x
  • x 3
Remove your access door to replace RAM chips or to open the case of your iMac.
first image
Add Note Edit Step 1 — Access Door  ¶
  • Lay your iMac front side down on a table with the lower edge facing yourself.
  • Loosen the single Phillips screw in the center of the access door.
  • This screw is captive in the access door.
  • Remove the access door from your iMac.
For more information, check out the iMac Intel 20" EMC 2266 device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
