Page 1 of 1
Installing iMac G5 20" Model A1076 Power Supply
- Author: Walter Galan
- Difficulty: Moderate
Keep those electrons flowing by replacing your broken power supply!
Relevant parts
- View:
- Paginated
- Full width
Edit Step 1
Rear Panel
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
Edit Step 5 ¶
While depressing the connector lock, use a heavy duty spudger to pry the power supply connector away from its socket on the logic board.
It will be necessary to work from alternate sides until the connector is free.
Your power supply may have an ambient light sensor cable attached from the power supply to the logic board. If so, carefully use a spudger to push out the cable towards you using the sides of the cable alternatively to help you slide it out.
Edit Step 6 ¶
Lift the power supply slightly from its left edge, then grab each side and rotate the power supply toward yourself.
The power supply requires a large amount of force to remove. You may need to bend the edge of the front case toward yourself for enough clearance to remove the power supply.
There are several capacitors mounted to the logic board in close proximity to the power supply. Try not to disturb them, as they are delicate and may break off the board.
Page 1 of 1
