iMac G5 20" Model A1076 Hard Drive Replacement
  • Add Note x
  • x 31
Upgrade your hard drive for more storage capacity.
first image
Add Note Edit Step 1 — Rear Panel  ¶
  • Lay the iMac display-side down on a flat surface.
  • Loosen the three Phillips screws securing the rear panel to the iMac.
  • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Lift the rear panel slightly near the bottom of the iMac.
  • Pull the rear panel toward yourself and remove it from the iMac.
first image
Add Note Edit Step 3 — Hard Drive  ¶
  • Remove the following three screws:
    • One shouldered 12.4 mm Phillips.
    • Two 7 mm T10 Torx.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #1 Screwdriver
$8.95 · 15 in stock
T10 Torx Screwdriver
$4.95 · 50+ in stock
Related Products
1 TB SATA Desktop Hard Drive
$199.95 · 13 in stock
2 TB SATA Desktop Hard Drive
$249.95 · 11 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 17 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
