Installing iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
  • x 10
Install an Airport Extreme 802.11g card internally.
first image
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
first image
Add Note Edit Step 2  ¶
  • Lift the battery out of the computer.
first image
Add Note Edit Step 3 — AirPort Extreme Card  ¶
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Next » « Previous
Required Tools
Flathead 3/32" or 2.5 mm Screwdriver
$4.95 · 50+ in stock
Coin
$2.95 · 16 in stock
Related Products
Airport Extreme Card
$39.95 · 50+ in stock
Notes Add Note Notes are offturn on
