Page 1 of 1
Installing iBook G4 12" 800 MHz-1.2 GHz Upper Case
- Author: iRobot
- Difficulty: Moderate
Changing the top case will also give you a new trackpad.
Sections
- Battery 2 steps
- Lower Case 12 steps
- Bottom Shield 2 steps
- DC-In Board 3 steps
- Upper Case 7 steps
Files
Tools
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit Step 22 ¶
Remove the following 7 screws from the edges of the keyboard area.
Three 2 mm Phillips along the right edge.
One 4.5 mm Phillips underneath where the magnet was.
One 6 mm Phillips with a small head in the lower left corner.
Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle
Edit Step 23 ¶
Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps.
Lift the upper case from the right side and use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab. Due to model variatons your trackpad connector may be different from the one pictured.
Edit Step 25 ¶
The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
Edit Step 26 ¶
Lift the upper case off completely and disconnect the multicolored speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
Tip: the multi-coloured cable may be easier and less daunting to disconnect after removing the top heat shield. Prop the top case upright while removing the shield - the connector is then much more accessible.
Page 1 of 1
