Page 1 of 1
iBook G4 12" 800 MHz-1.2 GHz Hard Drive Replacement
Replace the hard drive in your 800 MHz - 1.2 GHz iBook G4 12".
- Author: iRobot
- Difficulty: Difficult
You can install hard drives up to 9.5mm thick.
Sections
- Battery 2 steps
- Keyboard 7 steps
- Lower Case 12 steps
- Bottom Shield 2 steps
- DC-In Board 3 steps
- Upper Case 7 steps
- Top Shield 2 steps
- Hard Drive 4 steps
- Hard Drive Replacement 3 steps
Files
Tools
- View:
- Paginated
- Full width
Edit
Step 3
Keyboard
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Edit
Step 29
Remove the following 7 screws from the edges of the keyboard area.
Three 2 mm Phillips along the right edge.
One 4.5 mm Phillips underneath where the magnet was.
One 6 mm Phillips with a small head in the lower left corner.
Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle
Edit
Step 30
Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps.
Lift the upper case from the right side and use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab. Due to model variatons your trackpad connector may be different from the one pictured.
Edit
Step 32
The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
Edit
Step 33
Lift the upper case off completely and disconnect the multicolored speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
Tip: the multi-coloured cable may be easier and less daunting to disconnect after removing the top heat shield. Prop the top case upright while removing the shield - the connector is then much more accessible.
Edit
Step 42
Use the transparent orange loop to disconnect the large orange ribbon cable from the hard drive.
This is a bit tricky. Try rocking the cable gently from side to side while applying even pressure. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
If you are installing a new hard drive, we have an OS X install guide to get you up and running.
Page 1 of 1
