Installing iBook G4 12" 800 MHz-1.2 GHz Display Inverter
Add Note Introduction
Replace a faulty display inverter with the display attached to your iBook.
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Battery
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
first image
Add Note Step 2
  • Lift the battery out of the computer.
first image
thumb image 1
thumb image 2
Add Note Step 3 — Rear Display Bezel
  • Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
  • If you don't have a 1.5mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
Notes
There are no notes
