Page 1 of 1
Installing iBook G4 12" 1.33 GHz I/O Bezel
- Author: Walter Galan
- Difficulty: Difficult
Replacing the plastic covering surrounding the input and output ports.
Sections
- Battery 1 step
- Keyboard 3 steps
- Lower Case 12 steps
- Bottom Shield 2 steps
- DC-In Board 2 steps
- Upper Case 6 steps
- Top Shield 2 steps
- I/O Bezel 2 steps
Files
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 2
Keyboard
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Edit
Step 23
Remove the following 7 screws from the edges of the keyboard area.
Three 2 mm Phillips along the right edge.
One 4.5 mm Phillips underneath where the magnet was.
One 6 mm Phillips with a small head in the lower left corner.
Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle.
Edit
Step 24
Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps. Be especially careful with these cables; never pull directly on the cables, but use a spudger to pry up the connector directly.
Carefully lift the upper case slightly and move it toward the front of the computer to reveal the trackpad connector. Use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab.
After disconnecting the track pad connector, carefully rotate the upper case away from you and rest it against the display.
Edit
Step 25
The connectors at the ends of the following cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
Use the sharp end of a spudger to disconnect the speaker cable connector.
Edit
Step 26
Using the sharp end of a spudger, disconnect the connector for the blue and white power cables. Again, be careful to pry up only on the connector.
The key is to apply force in two directions, down to keep the surface board connections intact, up to release the connector.
The upper case is now free and can be removed from the computer.
Page 1 of 1
