Installing iBook G3 Clamshell RAM
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
  • x 6
One RAM slot will accept PC100 or PC133 chips up to 512 MB.
Sections
Files
first image
  • Use a coin to turn both battery locking screws 90 degrees to the left.
  • Remove the battery cover.
  • Remove the battery from the computer by pulling up on the plastic tab.
first image
Add Note Edit Step 2 — Airport Card  ¶
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
  • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
first image
Add Note Edit Step 3  ¶
  • If your computer does not have an airport card, you can skip the next two steps.
  • Grasp the clear plastic tab on the airport card and pull up and toward the display.
Next » « Previous
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 16 in stock
Related Products
PC133 512 MB RAM Chip (New)
$49.95 · 6 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
