Installing iBook G3 14" Keyboard
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
  • x 6
Replacing this keyboard is easy and takes only a few minutes.
Sections
Files
Tools
first image
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Keyboard  ¶
  • Pull the keyboard release tabs (highlighted in red) toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
first image
Add Note Edit Step 3  ¶
  • If your computer does not have an AirPort card installed, skip to the RAM shield removal step.
  • Push the wire clasp toward the AirPort card and pull it up to free it from the RAM shield.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 16 in stock
Related Products
iBook G3 12" Keyboard (Short tab)
$69.95 · 1 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
