Installing iBook G3 14" Airport Card
  • Author: iRobot
  • Difficulty: Easy
  • Add Note x
Install an original Airport 802.11b card internally.
Sections
Files
first image
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Airport Card  ¶
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
first image
Add Note Edit Step 3  ¶
  • If your computer does not have an Airport card installed, skip to the RAM shield removal step.
  • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
first image
Add Note Edit Step 4  ¶
  • Grasp the clear plastic tab on the Airport card and pull toward the right.
first image
Add Note Edit Step 5  ¶
  • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
For more information, check out the iBook G3 14" device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
