Installing iBook G3 12" Fan
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
  • x 3
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Sections
Files
Tools
first image
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Edit Step 2 — Lower Case  ¶
  • Your laptop should look approximately like this.
first image
Add Note Edit Step 3  ¶
  • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 48 in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 16 in stock
Related Products
iBook G3 12" Fan (500/600)
$9.95 · 10 in stock
iBook G3 12" Fan (600+)
$9.95 · 13 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
