eMac PRAM Battery Replacement
  1. eMac PRAM Battery Replacement, PRAM Battery: step 1, image 1 of 2 eMac PRAM Battery Replacement, PRAM Battery: step 1, image 2 of 2
    • Lay a towel (to protect the screen) on your work area and place the unit face down with the bottom facing you.
  2. eMac PRAM Battery Replacement: step 2, image 1 of 2 eMac PRAM Battery Replacement: step 2, image 2 of 2
    • The access panel is held in place by one Phillips screw. Unscrew it.
    • Unplug the machine after touching the metal housing to prevent ESD (electro static discharge)
  3. eMac PRAM Battery Replacement: step 3, image 1 of 1
    • The battery is located just to the left and below the RAM slots.
    • Note the positive is to the right and negative to the left. There is a + sign located on the logic board to the right of the battery.
    • Care must be taken when removing the battery to prevent it dropping into the machine. It pulls straight out. Use a small instrument like a dental pick or flathead screwdriver to lift the + end out. I use a large hemostat to hold the battery.
    • After removal of the old battery and replace with a new one by pressing it into place.
    • Replace the access panel. Turn it over and plug it in. Start up and go under the Apple to System Preferences - System - Date & Time. If you have an internet connection check the box to automatically and select Apple Americas.
    • If no internet just set the date and time manually.
    • Next select the Time Zone box. Click the curser on the map to the closest city to you.
    • Next click the Clock box and select the type of display you prefer.
25 other people completed this guide.
mayer
685,304 Reputation
12 Guides authored
MacHale Enterprises Member of MacHale Enterprises
Business
1 Member
18 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 55
All Time: 23,212
