Page 1 of 1
Installing Xbox 360 Cooling Fan Duct
Cooling fan duct replacement.
- Author: Walter Galan
- Difficulty: Difficult
Use this guide to remove the molded plastic fan duct from your Xbox.
Sections
- Hard Drive 1 step
- Bottom Vent 6 steps
- Faceplate 3 steps
- Top Vent 6 steps
- Lower Case 11 steps
- Eject Button 1 step
- Upper Case 2 steps
- Optical Drive 4 steps
- Cooling Fan Duct 1 step
- View:
- Paginated
- Full width
Edit
Step 3
In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
You will insert the tool into the holes molded into the white plastic side case pieces.
Edit
Step 8
Faceplate
Insert the edge of a spudger between the faceplate and the outer casing near the power button.
Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
You may also accomplish this task by using the edge of the Xbox 360 opening tool, but it may scratch the plastic case.
Alternatively, you can use your hands to carefully pull the faceplate away from the Xbox.
Edit
Step 18
The upper and lower cases are attached via several latches, located in the front and back of the console. These latches must be disengaged to separate the upper case from the console.
Use the flat end of a spudger to release the following latches:
Above the front-facing USB ports.
Beneath the front-facing USB ports.
Above the Memory Unit slots.
Edit
Step 23
If you used an Xbox 360 opening tool on the previous step, skip this step.
While pushing the upper and lower cases apart, insert the pointed end of a small metal spudger into the recesses located near the I/O ports and push downward to release each retaining clip.
Work from the outer edge of the case inwards.
Edit
Step 24
While pushing the upper and lower cases apart, use the tip of a spudger or the finger of an Xbox 360 opening tool to push the long clip highlighted in red toward the center of the 360.
The clip should release, leaving the clips near the power connector as the only thing holding the upper and lower cases together.
Edit
Step 28
Eject Button
Use the tip of a spudger to release the clip securing the eject button to the metal casing.
Insert the flat end of a spudger between the eject button and the optical drive.
Pry the eject button off its retaining posts and remove it from the 360.
This can also be accomplished using an Xbox 360 opening tool.
Edit
Step 35
Cooling Fan Duct
Insert the flat end of a spudger into the small rectangular opening on the top of the cooling fan duct.
Carefully release the fan duct retaining clip and remove the fan duct from the Xbox.
The clip can alternatively be released using the metal finger of an Xbox 360 opening tool.
This guide has been completed 7 times.
Page 1 of 1
