Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement
  1. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Battery: step 1, image 1 of 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Battery: step 1, image 2 of 2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: step 2, image 1 of 1
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: step 3, image 1 of 3 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: step 3, image 2 of 3 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: step 3, image 3 of 3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: step 4, image 2 of 2
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, CCD Sensor Module: step 5, image 1 of 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, CCD Sensor Module: step 5, image 2 of 2
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: step 6, image 1 of 1
    • Grasp the CCD Sensor Module and remove it.
3 other people completed this guide.
iDeleted
2,101 Reputation
39 Guides authored
1 Guide Comment
where I can buy it?
Francesco Cortese - Reply
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 64
All Time: 14,114
