Page 1 of 1
Installing PowerBook G4 Titanium Mercury Logic Board
- Author: iRobot
- Difficulty: Difficult
The motherboard - which includes all ports and the DC-In board - is fairly easy to change.
Sections
- Keyboard 3 steps
- RAM 1 step
- Lower Case 3 steps
- Airport Card 1 step
- Hard Drive 4 steps
- DVD Drive 4 steps
- Modem 3 steps
- Logic Board 6 steps
- View:
- Paginated
- Full width
Edit Step 13
DVD Drive
Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out.
Carefully peel the adhesive strip away from the DVD drive. The plastic dust shield covering the DVD drive is easily damaged. Try to start at the four corners and work toward the center.
Edit Step 16 ¶
Remove the DVD drive by lifting the right edge up and out of the computer.
If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Edit Step 24 ¶
Carefully lift the logic board up and pull it away from you. The logic board may catch on the back panel ports liner. If this occurs, use a spudger or non-metal tool to free the logic board.
This step requires some force, but if the logic board will not come up, make sure you have removed all screws and connectors necessary.
Remove the logic board from the computer.
This guide has been completed 7 times.
Page 1 of 1
