Installing PowerBook G4 Titanium Mercury Hard Drive
Prerequisite Only This guide is only used as a prerequisite for other guides and is not a complete or useful guide when viewed independently.
Author:
iRobot Difficulty: Easy
How to remove the hard drive, along with its cable and bracket from your computer.
Embed this guide With the HTML code below, you can embed this guide as a small widget on your website.
Edit Step 1
Lower Case
Using your thumbs, slide the lower case away from you.
The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
Edit Step 4
Hard Drive
Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
For more information, check out the PowerBook G4 Titanium Mercury
device page .
Fantastic! Great work!
Your profile has been updated to show that you completed Installing PowerBook G4 Titanium Mercury Hard Drive. Change your mind? Oops, I actually didn't do it.
Did you successfully follow this guide? I did it! Success!
This guide has been completed 6 times.
