Installing PowerBook G4 Titanium Mercury Airport Card
Author:
iRobot Difficulty: Easy
Install an original Airport 802.11b card internally.
Embed this guide With the HTML code below, you can embed this guide as a small widget on your website.
Sections Files Tools Relevant parts
Edit Step 1
Lower Case
Using your thumbs, slide the lower case away from you.
The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
Edit Step 4
Airport Card
Skip this step if your computer does not have an Airport card.
Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
Disconnect the antenna cable from the left side of the Airport card.
For more information, check out the PowerBook G4 Titanium Mercury
device page .
Fantastic! Great work!
Your profile has been updated to show that you completed Installing PowerBook G4 Titanium Mercury Airport Card. Change your mind? Oops, I actually didn't do it.
Did you successfully follow this guide? I did it! Success!
This guide has been completed 2 times.
