Installing PowerBook G4 Titanium DVI Lower Case
Add Note Introduction
The bottom case slides off easily after removing a few T8 Torx screws.
Tools used in this guide
Parts relevant to this guide
Paginated Single Page Steps
first image
thumb image 1
thumb image 2
Add Note Step 1 — Battery
  • Locate the battery release tab on the underside of the G4.
  • Slide the battery release tab to the left and lift the battery out of the computer.
first image
Add Note Step 2 — Lower Case
  • Remove the seven T8 Torx screws from the lower case.
first image
Add Note Step 3
  • Using your thumbs, slide the lower case away from you.
  • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
  • Lift the lower case off.
Notes
There are no notes
