View profile
Logout
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
« Back to device
Next »
Page 1 of 4
You can install hard drives up to 12.5mm thick.
With the HTML code below, you can embed this guide as a small widget on your website.
Locate the battery release tab on the underside of the G4.
Slide the battery release tab to the left and lift the battery out of the computer.
Remove the seven T8 Torx screws from the lower case.
Using your thumbs, slide the lower case away from you.
The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
Next » « Previous
$6.95 · 47 in stock
$39.95
$139.95 · 5 in stock
1024
