Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Modem
  • Add Note x
Replace your modem to regain dial-up internet access.
Sections
Files
Tools
first image
thumb image 1
thumb image 2
  • Use your thumbs to push the two battery retaining tabs away from the battery.
  • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
first image
Add Note Edit Step 2 — Memory Door  ¶
  • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
first image
Add Note Edit Step 4 — Upper Case  ¶
  • Remove the following ten screws:
    • Two 14.7 mm shouldered Phillips.
    • Three 12.3 mm Phillips.
    • One 3.8 mm T8 Torx.
    • One 6.8 mm T8 Torx.
    • Three 1.3 mm Phillips.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5  ¶
  • The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip.
  • Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
  • The ZIF cable lock will move about a millimeter away from the socket before it stops (see picture 2). Do not try to remove the ZIF cable lock.
first image
Add Note Edit Step 6  ¶
  • Use the tip of a spudger to slide the trackpad ribbon cable out of its socket.
first image
Add Note Edit Step 7  ¶
  • Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
  • When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
first image
Add Note Edit Step 8  ¶
  • Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
  • During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
first image
thumb image 1
thumb image 2
Add Note Edit Step 9  ¶
  • Depress the display latch release button and open your display.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
first image
Add Note Edit Step 11 — Modem  ¶
  • If necessary, peel back the strip of aluminum tape covering the modem cable.
first image
Add Note Edit Step 12  ¶
  • Use the flat end of a spudger to pry the modem cable connector up off the modem.
first image
Add Note Edit Step 13  ¶
  • Disconnect the RJ-11 cable from the modem.
first image
Add Note Edit Step 14  ¶
  • Use a 4 mm nut driver to remove the two nuts securing the modem to the PC card cage.
first image
Add Note Edit Step 15  ¶
  • Lift the modem straight up off the studs on the PC card cage.
For more information, check out the PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
