Page 1 of 1
Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Lower Case
- Author: Walter Galan
- Difficulty: Difficult
Replacing your lower case requires removing nearly every component from your PowerBook.
Sections
- Battery 1 step
- Memory Door 2 steps
- Upper Case 7 steps
- Speakers 21 steps
- Logic Board 13 steps
- Heat Sink & Fan Assembly 17 steps
- Lower Case 11 steps
Files
- View:
- Paginated
- Full width
Edit
Step 5
The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip.
Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
The ZIF cable lock will move about a millimeter away from the socket before it stops (see picture 2). Do not try to remove the ZIF cable lock.
Edit
Step 8
Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
Edit
Step 37
Disconnect both of the following connectors from the logic board:
Left fan cable.
Inverter cable.
Be sure to pull only parallel to the face of the logic board, as pulling up on the socket will break it off the logic board.
When pulling these connectors away from their sockets, it is helpful to use your fingernails to pull on the ears at each side of the connector.
Edit
Step 41
Disconnect the right fan by pulling its connector away from the socket on the logic board.
When pulling this connector away from its socket, it is helpful to use your fingernails to pull on the ears at each side of the connector.
Edit
Step 43
If necessary, use a spudger to pry up the left edge of the logic board to separate the solidified thermal paste from the heat sink.
If any resistance is felt when prying up on the logic board, we recommend softening the thermal paste by heating the board with a hair dryer before prying further.
Edit
Step 44
Lift the logic board from its left edge and rotate it toward the right side of the lower case.
The logic board on this model has a tendency to get caught on the lower case near the DVI port at the upper right corner. If it catches as you are rotating it, stop to avoid bending and breaking the logic board.
Rotate the logic board until it is nearly vertical, and wiggle it around until it releases from the lower case.
When reinstalling your logic board, be sure to apply thermal paste to the CPU. Our thermal paste guide makes it easy.
Only replace the gray thermal paste on the CPU. The white thermal material on the GPU chips can be reused.
Edit
Step 54
Before proceeding, be sure your display is perpendicular to the lower case.
Remove four T6 Torx screws from the left display hinge.
We intentionally have you leave one screw in the left display hinge to aid in disassembly.
The screw holding the plastic display cable bracket to the lower case is shorter than the rest.
Edit
Step 57
Lift the display straight up from the lower case, minding any cables that may get caught.
Check out our display install tips to help properly reinstall your display.
Page 1 of 1
