PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Logic Board Replacement
Replace the logic board in your PowerBook G4 Aluminum 17" 1.67 GHz (High-Res).
  • Add Note x
This motherboard includes all ports on the right side except USB.
Sections
Files
first image
thumb image 1
thumb image 2
  • Use your thumbs to push the two battery retaining tabs away from the battery.
  • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
first image
Add Note Edit Step 2 — Memory Door  ¶
  • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 47 in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
