Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery
  • Add Note x
Replace a worn out battery for longer intervals between recharging.
first image
thumb image 1
thumb image 2
  • Use your thumbs to push the two battery retaining tabs away from the battery.
  • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
For more information, check out the PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) device page.
Did you successfully follow this guide?
Notes Add Note Notes are offturn on
