Page 1 of 1
Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) AirPort/Bluetooth Board
- Author: Walter Galan
- Difficulty: Moderate
Replace your AirPort/Bluetoo
Sections
- Battery 1 step
- Memory Door 2 steps
- Upper Case 7 steps
- Modem 5 steps
- PC Card Cage 6 steps
- AirPort/Bluetooth Board 5 steps
Files
- View:
- Paginated
- Full width
Edit
Step 5
The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip.
Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
The ZIF cable lock will move about a millimeter away from the socket before it stops (see picture 2). Do not try to remove the ZIF cable lock.
Edit
Step 8
Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
Edit
Step 23
Remove the single Phillips screw securing the AirPort/Bluetooth bracket to the lower case.
It is possible to remove the AirPort/Bluetooth board without removing this screw. Alternatively use the sharp end of a spudger to press the metal pressure connector (shown in orange) down through the hole in the AirPort/Bluetooth board, being careful to not break it off when prying the board up in the next step.
Page 1 of 1
