Installing PowerBook G4 Aluminum 17" 1-1.67 GHz Speakers
Add Note Introduction
Restore sound to your laptop by replacing the speakers.
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Battery
  • Orient the computer so that the side with the line of screws on it is away from you.
  • Use your thumbs to push both battery release tabs away so that the edge of the battery lifts up.
  • Lift the battery out of the computer.
first image
Add Note Step 2 — Upper Case
  • Remove the three identical Phillips screws from the memory door.
first image
Add Note Step 3
  • Lift the memory door up enough so that you can get a grip on it, and slide it toward you, pulling it away from the casing.
Notes
There are no notes
