View profile
Logout
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
« Back to device
Next »
Page 1 of 2
Two RAM slots allow up to 1 GB of PC2700 RAM.
With the HTML code below, you can embed this guide as a small widget on your website.
Orient the computer so that the side with the line of screws on it is away from you.
Use your thumbs to push both battery release tabs away so that the edge of the battery lifts up.
Lift the battery out of the computer.
Remove the three identical Phillips screws from the memory door.
Lift the memory door up enough so that you can get a grip on it, and slide it toward you, pulling it away from the casing.
Next » « Previous
$4.95 · 50+ in stock
$54.95 · 14 in stock
$39.95 · 12 in stock
$24.95 · 50+ in stock
$7.95 · 50+ in stock
$59.95 · 50+ in stock
$6.95 · 50+ in stock
1024
